508 pump gas, 89/93 oct fuel 99 oct slows it down
Stock block 4.420
Dished pistons
MSD Box
4.140 cast offset ground ford crank
D2 POLICE HEADS , ported
Hooker Headers,with flow master mufflers 3''
Stock dist,locked out @ 44 total tried 30 to 48,and diff fuel , 44 was best
Hyd cam, Flat tappet
stock waterpump
full ehx,to rear bumper w/h pipe 3''
alt,stock fan, pulleys etc
carter manuel fuel pump
stock fuel line
victor intake, One on it right now isnt ported
/\ < have tested a victor not ported, factory dual quad,dual plane,other single planes, perfomer rpm, and 1850 holley to 1250 cfm carbs on this engine . victor ported with a 4500 dom carb ran best.
this engine is in a 4400 lb car with driver
Leaving it in DRIVE it ran 12.36 best, thru the mufflers , just floor it
Drive it to the track,and home
Oh no you posted 44* total timing, the dyno racers are gonna jump on you about how an iron head doesn't need that much timing!:eek::rolleyes: Despite we have both seen the difference ignition lead makes going down the dragstrip.
One of the reasons I started posting some of these
IN FACT with any less timing it will slow down.
have another shortblock 508 like this for sale at this time
new pistons,rings not installed
pump gas
