i have a 78 lincoln short block with procomp. heads with 225 intake valves ,176 exhaust valves, crower cam 22244 with intake dur.311 lift 588 exhaust: dur.316 lift 604 with 112 LS [email protected] 246/250, edelbrock performer intake /w torker avail.edelbrock 800cfm carb..will this combo work? what would you change? any comments will help ..the motor isnt in the car yet..
Did you put flat tops in it ? If not The only thing I see wrong is the compression will be low. Also run the torqer intake if you have flat tops in it.
Should run good.............
Stock pistons
If you still have the stock style piston you will need to add some clearance for the intake valves.
Andy
