one pair (2 individual pieces) of Yella Terra YT6321 (BBF) pedestal rocker arms with pedestals and bolts. purchased as spares for $250 and never bolted on a cylinder head. Will also include a couple pushrod cups/adjuster screws. $125 shipped.
5 speedpro hyperutectic H535CP .030"over with coated skirts - used and in good shape. $60 for all shipped obo
Isky redzone roller lifter set p/n3172-RH used all rollers spin smooth and bodies slide smoothly in bores, pressure oiling to rollers. Isky will rebuild for $13 each if the need ever arises $385 shipped
Isky roller valve springs used p/n 9985 245lbs at 2.000" 600lbs at .700" lift max $50 shipped
K-motion K1000H valve springs in very good shape, used for one season.
1.625'' Dia. Double H-11 Valve Springs with Damper,
Seat Load: 265lbs @ 2.000''
Open Load: 825lbs @ 1.200''
Coil Bind: 1.090''
Max Lift: .850''
$125 shipped
10 (ten) Strange Engineering thread in wheel studs, 4.000" over all length, 5/8 thread, .685" shaft, used on draglites with strange axles. went with different wheels and shorter studs, they are like new. $35 shipped
SCAT sfi FP-460 external balance 164 tooth flexplate, ford and gm convertor pattern used, all teeth are fine. $40 shipped
Comp Cams .125" wall 3/8 - 7/16 dual taper pushrods used
15 - 8.900"
11 - 8.850"
make offer these things are over $10 a piece new
SBF package
CNC ported victor JR heads standard exhaust flange, 2.05/1.60 stainless valves, 7/16 studs, hyd roller springs, steel retainers, 64 CC chambers, flow #'s available. NEW!
comp cams hyd roller cam
dur at .050 244 int and exh
lift .612 int and exh with 1.6 rockers
lobe seperation 114. NEW!
felpro 1011-2 head, 1262 intake and 1415 exhaust gaskets. NEW!
$1900 shipped
A lot of the parts from the first ad have sold, thanks guys and chilly. I really just want the rest of this stuff gone. It does me no good sitting here, any questions or offers contact me here or call 608-279-1812 evenings.
thanks
Dave
Coil Bind: 1.090''
Max Lift: .850''
$125 shipped
15 - 8.900"
11 - 8.850"
SBF package
$1900 shipped
thanks
Dave
