1 - 17 of 17 Posts
Looking for a water pump pulley for 1968-69 429 tj. Having one in hand will allow me to start a project. Thanks!
You are retaining the short nosed water pump and matching damper with pulley groove?
I will look through my stash. I have complete bracket and pulley sets for 70 and up but just bits and pieces for the 68 and 69's.
SJ
That’d be a huge help if you found anything. The motor came to me with a crank pulley on it (internal balancer I believe) but is missing the water pump pulley and brackets. My project can get going once the missing stuff is sourced. Thank you for your help for sure
....but yes, I have the old short nose water pump in hand and I assume the current crank pulley is stock.
That is the early damper.
I'm still looking. Many boxes stashed away.
SJ
used 2b RHP
:D
Do you really need the short water pump? Is it going back in a T Bird or Lincoln,etc? If not,might be easier to get the whole setup from a later motor. The brackets and pulleys that go with the short pump are unique. Guys have them laying around but don't know it.
I have two complete 68 T-bird water pump set ups with timing cover, and crank mounted power steering pumps with pulleys and fluid reservoirs on my shelf. Both in greasy take-off condition.
It's the same pump that was used on Boss 429's, so you're not likely to find one cheap unless the seller doesn't know what they have.
C8SE-8505 pumps are getting harder to find and do fetch around $200, if your lucky for a core.
I checked and I do NOT have the proper wp pulley.
I've attached a pic of a 1969 429 pulley / bracket set up. Dual alternator belt, p/s belt and AC as well.
Second pic shows the install of the original alternator dual pulley.
What is your application? If not going back into a 68 or 69 vehicle you can use the later water pump, damper, pulleys and brackets which I have along with a thompson power steering pump.
The 460s in the Lincolns utilized a crank driven PS pump and reservoir with a different front cover, crank spacer, accessories and brackets. Scratch that idea.
The last pic is of the later brackets and pulleys for a 1970 to mid 70s application with a york a/c compressor.
These are on my LTD and sourced from a 1970 Thunderbird. Also found in full size to about mid 70's. The thunderbird and Lincolns started using a GM style a/c compressor and p/s pump in 1972.
I will post the remaining pics in another reply.
SJ
used 2b RHP.
:D
Pics showing brackets, pulleys and alternator / WP on my LTD with out Fan in the way. Later long style.
SJ
Carl,those setups work great for a Fox swap.You can get a big ol fan and clutch behind a perf type radiator with the stock shroud. The ps pump itself...not so good.They won't handle much rpm and had a complete car oil down to prove it.You use the balancer,wp pulley,crank pulley,alt brackets,standard timing cover,cut about 1/4 off the crank spacer and you're in business.You have to get creative with the power steering but I went with an electric deal that works great.
Jack at Dead Nuts On has the rebuild kits for the short pump.
Scotty,you're gonna hate that Thompson pump before it's all over with.
I've had spectacular luck with the thompson p/s pumps. It is the later pumps that are noisy and troublesome in my experience.
That Thompson pump has been on the car for 7 years and is the original to the car from 1973.
Crank driven are an option when you can properly reseal etc...
SJ
Discussion Starter #15 (Edited)
Thanks for the reply. It's a 68 429 out of a Tbird. It's going in a 1975 F250. The 1975 had the 460 option so I'm sure the long nose would fit. I just have no idea what to do to switch it from a short nose to a long nose. Haven't been able to find a write-up it.
Discussion Starter #16
It's going in a 1975 F250, which had the 460 option, so the long snout should fit in there. Not sure what I need to do to "update" it but will definitely need to get whatever is needed! I'm new to this stuff.
Cost effective aluminum brackets and pulleys.
https://www.cvfracing.com/ford/ford-big-block-429-460/
SJ
used 2b RHP
:D
1 - 17 of 17 Posts
