21 - 38 of 38 Posts
You can add an open 1/2" or 1" spacer is you need more ht.
Ok, open spacer works better than gloverleaf spacer with powercone? Or would the best option be to open up the top of the intake to match the open style spacer like some of the BBC intakes are opened as open square for Dominator?
Is the powercone worth of the effort?
are these two inch spacers? Do they come with gaskets? can I bolt them on top of a two inch 4150 to 4500 adapter? Thanks Lem
Any info on the 3 hole 4150 spacer that Scotty uses?
I need another cone Lem, going back to gas. It's for the same carb QF 4700 2 circuit. Already ordered it from Oakley.
I'll be calling later today.
Thanks,
John
I'm not sure what Scotty uses.
It's a 4 hole 4150 style that has the divider removed between the pri and sec one side that equalizes the plenum on a Performer intake. He said he gets them from you.
21 - 38 of 38 Posts
