1 - 10 of 10 Posts
S
Guest
Hi,
The truck came in with a trans code for a pressure solenoid. We changed the solenoid. Still has code.
Some details and I believe I have two problems at hand:
When I started it up (cold) it was missing for a couple of seconds then kind of cleared up. I brought it into the shop. If you put it in gear and give it some throttle (700Rpm) it will start missing. Take it out of gear and flash the throttle it will rev but with a hit of a missfire.
Using the Snappy Red Brick..When it's in gear& depress the throttle to 700 Rpm.. the O2's will go to zero and it will sound like a lean rattle (missfire). When it does this it goes into open loop.
The brick shows No on the missfire and Injectors are OK..
I looked at the TPS with the engine off and the sweep doesen't seem to drop off on the scanner.
The Troubleshooter in the Red Brick says to disconnect the MAF and try that.. It don't seem to effect the lean condition as the O2's will go to zero. I disconnected the battery to reset the Baro and that didn't help.
The truck had orignal plugs at 96K miles so we changed them and the friggin long azz wires.
Fuel pressure is Good and it appears that the customer had replaced the fuel filter because it was new looking.
Well any ideas on the lean conditions?? I did check for a vac leak but cant hear any??
I still have that code of the tranny but no other codes..
Thanks Pal!
Les
S
Guest
Discussion Starter #2
One more tid bit.. We used Autolite plugs with the Platium on the electrode.. The plugs in the truck were Motorcraft with the platium on the "J" or ground strap.. Does this make a difference?
If it's missing it will show a lean condition because the O2 sensors read oxygen. IE, the oxygen is not burning with the fuel. In a nice complete burn there's a certain amount of oxygen left in the exhaust just like there's a certain amount of fuel left unburned. Does it have a coil gone bad? I had a 4.2 v6 ford (may have been 4.0, can't remember) that ran almost consistent with what you are talking about and I removed the coil pack, compared resistance across the primary and secondary circuits to a new coil, found a difference and thought, what the heck. Bought the new coil pack and problem was solved.
S
Guest
richter69 said:
they got trucks that burn gas?????
sorry man, i aint no help here.
TY Jon.. Just figured ya may have ran acrossed this problem at the dealer..
Ya Rock and tY for the reply!
Les
S
Guest
I agree.. I had a good know coil and tried it on one side.. No Help.. Put the timing light on the wires on the other side (one at a time) and didn't see any spark falling off.. It's a tough one.. I guess I'll keep at it!
Thank you for the suggestion..
Les
S
Guest
Thanks all..
Swapped in another computer and that fixed it.. Crazy how a Tranny soloniod would take out the computer?
On the flip side.. My research says not to install Autolite Pluge in the 4.6.
The Motorcraft plugs have the Plaitmum on the ground strap, while Autolite have it on the electrode. Not sure if having the Platitumn on the electrode causes more resistance..
Interesting at best..
amp draw......
that's why you should have used the double platinum plugs. they have it on both sides.
S
Guest
Fordtek1 said:
amp draw......
Got ya.. Sticker Shock for the customer.. Any Plugs you suggest that are DDB Plat other then Autolite?
Thanks for the reply
1 - 10 of 10 Posts
