I useally read the factory compression as advertised is a little higher then it is actually. I would guess you be around 9.5 to one with the taller block , thinking the 429 was no more then actually 10 to one with early block. Most shops will deck a given amount for around 100$. I would have take .025 off and call it good.It be better to install a rod piston in all four corners to get a better idea, if you dont mind the extra work.
