Hello all,
Over the winter I plan on installing a ZEX system 82048 on my motor. To start I have 69' block, with SCAT 514 stroker kit with 6.8 H beam rods. Motor completely studded. Cometic head gaskets. Off the shelf roller cam, DOVE gutted heads, double valve springed alittle over recommended cam specs. Victor manifold with 1050 dom 8896-1. I have best a 10.18 with 1.39 sixty's. Just realized recently that my fuel pump was regulated at the pump @ only 6-8 psi! :shock: Now regulated at 21-23 psi, then regulated to 6-6.5 at the carb. That would explain my low mph which would be at 131-133. I have not been back to the track since the discovery, Anyway.....
Once I install this system, what kind of adjustments should I be looking to make on the carb. I know that I will have to use a y block to run a separate regulator for the nitrous. I know that I will have to retard the timing per the chart supplied if not 1 degree more than what they recommend. Should the carb have the power valve or should they be removed.
I will be using a WOT switch so the real noobie questions......Do I have to hold a stupid button all the way down the track? lol Is it best to spray entire run or if money provides use a timer? Will the DOVE heads be able to handle this? Only PLAN on using 150 shot max. I just want to hit that mid 9 sec and I would have surpass my original goal and that was build a 10 sec car right from the start.
Hello all,
Couple things....
First, lose the PV and square up the carb jetting. You need to get the carb as close to perfect on HP before you spray it. I assume your reading plugs after every pass?? Once the carb is right you shouldn't need to touch it when you do start to spray it.
Use a WOT on the throttle linkage and that will be your "button". The tune up that will come with the ZEX kit will be VERY safe. Follow the directions but plan on making FP changes to the N2O side as well as jet changes to the plate. Again, read plugs
Not sure about your build but I've been basement 9's lifting @ 1000ft in crappy air with a 42 jet (about 60hp:rolleyes:) in the plate. Iron headed 508. You should get into the 9's fairly easy
PM me for more info. This is the same Tony on CMC. I'll give ya a hand with whatever you need
Couple things....
Cool.....nice to know that you can help me out. Just gathering as much info as I can before time to install. Thanx for answering about the PV's too.
