I have a 95 f250 I'm setting up with a megasquirt /eec parallel setup, I plan on swapping to a megasquirt based trans controller as well after I learn some stuff.
Anyways, I was hoping someone has access to the stock eec timing map, so I have some idea of a baseleline to go off of.
I'm staying sd/batch for the time being but with a wide band. Engine is stock.
Anyone on here play with MS/tunerstudio? My head is spinning a bit!
I plan on making the setup swappable so I can switch back and forth between stock and the ms (actually a Microsquirt) so I don't get stuck in a situation I can't figure out.
A timing base map(or at least some MAP based points!) stock 24# injector dead times and flow chart would help a lot! I haven't been able to find much of anything on these trucks.
I've been trying to find the base timing map for the stock eec setup as well and have come up with nothing as of yet, including a request to HPTuners. Good luck!
