I've been using a Lentech Strip Terminator AOD transmission in my '78 Bronco, successfully for years. No electronics, just a throttle valve cable! (The AODE can't be built as strong.) I LOVE IT! Truly a world class piece of workmanship. I will never use any other transmission. Mine is the Stage 1 Strip Terminator AOD capable of 1000 horsepower. They make a Stage 2 AOD capable of 1500 horsepower. I first had an Art Carr AOD built for this application, but I blew it up in less than a year. Then I got serious and had Dynamic Racing Transmissions http://www.dynamicracingtrans.com/ (North Branford,CT) build the Lentech Strip Terminator AOD. (Not affiliated with Lentech Automatics in Canada, but they often work together.) No comparison...I've beat the heck out of this transmission and never had a problem.
This transmission was behind my mild (high torque truck) 466" for years and it's now behind a fresh, potent 508" engine. The low first gear of the wide ratio planetary gearset (2.84:1) and the pushbutton overdrive (.70:1) really give you the best of both worlds (if it's a street vehicle). (I don't like the E4OD...too heavy, too long, too much drag, requires expensive conversion electronics and can't be built as strong.)
Here's some quick specs:
Lentech Strip Terminator AOD (fully automatic/gearshift selectable 1st, 2nd and 3rd with pushbutton overdrive), JW Ultra-Bell SFI bell housing, Dynamic Racing Trans/TCT 10” 2500 rpm stall (non-lock up) torque converter, 300M 31 spline one-piece input shaft, FRPP wide ratio planetary gearset (2.84 1st 1.55 2nd 1:1 3rd .70 overdrive), Lokar stainless steel braided throttle valve cable kit, Lokar stainless steel braided flexible dipstick, finned aluminum deep (2 quart extra capacity) oil pan, very large (48 pass) Tru-Cool transmission fluid cooler with Aeroquip -6 AN fittings & stainless steel flex hose, Auto Meter 2259 temperature sensor, CSR Torque Master flexplate
Here are two links:
http://www.lentechautomatics.com/aodproducts.html
http://www.lentechautomatics.com/striptrans.html
I highly recommend using the JW Ultra-Bell (adapter bellhousing). If you decide against their adapter bell housing, then the Lentech adapter plate is the next best method of adaptation. It is 5/8" thick and won't flex. I feel it is the best AOD to 460 adapter plate on the market; besides the JW Ultra-Bell. (Don't ask me how I know...I first made the mistake of buying the Art Carr 3/8" thick adapter plate.)
If you want the installation details, you can read my Complete Overdrive Conversion Article here:
http://www.fordtrucks.com/article/i...verdrive_Conversion_for_7879_Ford_Bronco.html
Here are two links:
