41 - 60 of 63 Posts
Hey,in case you don't already know,West System epoxy resin is awesome stuff for fabricating fiberglass. Works great for adding metal parts or just forming new parts. Super strong! 105 resin,205 fast activator,206 slow.I use slow but it takes 24 hrs to cure. The 406 additive...you mix it with the stirred resin to get the mixture as thick as you want,wont run off or sag when it's the right consistency.
Discussion Starter #43
Once the body comes off for frame mods, there's quite a bit of 'glass work to do. Good to know since the firewall is a big project and the trunk corners are being changed as well.
Discussion Starter #44
One more thing down. The rear drums were used and junk, so after researching what I'd need and sourcing them, got all new parts for an Explorer disc conversion for under $300 total. Had to swap sides on the caliper brackets so the parking brake exited on the bottom and not the top, but shouldn't present a problem bleeding the brakes. Now I'll be able to stop it.... just need to get around to the engine so I can make it go!
Discussion Starter #45
You have to take the good with the bad. In looking it over closer, the previous owner didn't own a tape measure, so the shock mount/link brackets he tacked on the housing aren't the same distance from the ends, but more than that, the top shock mounts aren't spaced properly either. The good news? In re-doing all this I can set the pinion angle properly.......
Discussion Starter #46
So since the last post I've found out a few things
The PO might have owned a tape measure, but didn't use it well. The triangulated 4 link brackets were off, but after removing the body I found out why. No matter what I measured it all came back wrong. Finally measured the frame diagonally and it started making sense. The frame is racked (3/8-1/2") and all the bracket locations were to try to compensate. Figured it's best to cut it all out and start over, so out came the cutoff wheel and sawzall. When I made the last cut on the center x-member I heard that "tink" sound and knew the frame was under tension. Re-measured and it came back about 1/4", but it went to the body shop so it can be racked on the frame machine and straightened.
Changed direction on the rear suspension as I've always had doubts about trying to run decent HP through a non-adjustable triangulated setup. Going with an adjustable parallel 4 link when it goes back together. The car's purpose has changed a bit since it's become clear street duty will be REALLY limited, so why make so many compromises? Won't turn that well, but now I'll be able to tune the rear suspension to get a better launch.
This is a lesson to all of us. There is always a reason for an unfinished project and it's often not, "I have too many projects." There is a problem and the PO is unable or unwilling to fix it. Caveat Emptor (let the buyer beware) so value these things accordingly.
Good that you have the skills to overcome the PO's errors.
Discussion Starter #48
Out with the old, in with the new. A minor diversion that will give more adjustability and (hopefully) launch better.
There you go, now build a cage with plenty of bars to keep you safe in that paper mache body. That thing is gonna be an animal!!!
Discussion Starter #50
That's the plan! I've designed a double hoop roll cage (think funny car style) to keep me safe. As long as it goes straight, hooks up and stays on 4 wheels I'm happy.
As projects go,when there's no light at the end of the tunnel,one tends to pick away at things. When you see a faint glimmer,the pace picks up and the enjoyment level rises. Are you at that stage yet? I hope so cause I want to see the videos!!! Nice work!
Discussion Starter #52
Short answer is yes and no. In setting up the 4 link (frame still isn't back) I'm seeing things that need to be modified because of another change being required.
For instance, just last night I was trying to visualize the driveshaft movement and suspension articulation. Looks like I need to add a driveshaft hoop into the crossmember for clearance on compression. So THAT also means I need to pook that hoop up through the floor..... right where the inner seat brackets would be. So THAT means I will have to redesign the inner seat mounts with tabs on the topside of the hoop. It also means since I decided to use a wishbone locator instead of panhard, the center heim (mounting it on top and "backwards") will need to be changed from what I'd planned.
At this point I'm wondering if I'll be able to keep the Deuce rails and also seeing why I've never seen anyone try this before.
Yeah...on a deal like yours,there's a lot of "sizing up" to do and a lot of times,the sizing up you do today doesn't match up too good with what you sized up before.Put your engineering cap on. You will figure it out.
Discussion Starter #54
The shop is done with the frame and what they found explains a lot. First, I have no history on this frame as I bought the project assembled. Don't know who boxed the frame or the manufacturer, though the PO said it was a TCI (thinking that's BS now).
The right rail had more bow than the left (likely from boxing), so not only was it racked, the right side was shorter than the left as well. Had it on the frame rack for about 3 hours and when the excess bow was taken out it was only racked an 1/8". It was then squared and leveled, so I'm told it's now perfect from 3 points.
Now I can mock up the 4 link and get going on the roll cage. Time to play!
Discussion Starter #55
So far so good getting the 4 link set up. Going with a wishbone locator on top. Now to continue (or start actually) the frame reinforcement, seat and rollcage mounts.
Discussion Starter #56
Time to start multi-tasking. Got a good handle on the frame mods, so the engine needs some attention now. Found a guy in Beaumont that had a set of Lunati (Morel) solid roller lifters NIB and picked them up for a song. Last major engine piece left is the cam, so I'll be talking to some people this week to spec and grind one.
I know some of the pieces I have aren't optimal, but hopefully can be swapped out later once I have it running and sorted out. I know the SCJ heads will hold me back on lift, I can get more by ditching the Torker II and 950HP and going Dominator, putting more stall in it and see if 3.89's will get me close.
What color are you going to paint the garage floor? Nice masking job! GRIN
Richard
Discussion Starter #58
Richard
Kinda getting fond of the blue! I've marked the concrete in the past, but using painter's tape on the floor to mark frame points works out so much better. Easy to see, really easy to make changes if I need to (just put more tape over the affected section) and can make notes/dimensions on it. And when it's done just pull it up!
Discussion Starter #60
Almost looks like a car. Laying out the reinforcements in the floor then the body comes off again.
Coming up time to get the engine assembled and will need a custom cam so anyone here up to it?
41 - 60 of 63 Posts
