The original build for this engine was for a relatively mild flat tappet cam in the 545 so ordered the SCJ-A heads that come with 7* retainers and locks, milder springs. With this solid roller, I want to step up to 10* (like the SCJ-B) and need advice on springs as well as how much retainer I need (steel or titanium).I was sorta wondering the same thing! Also curious aboot the 10 deg and 7 deg lock thing as I've got a set of both I can use on my SCJ heads as well....
Thanks for the tips. Getting it decked the way I wanted was challenging, so had them deck it to 10.3. Leaves them .008" in the hole and with this head gasket (.041") brings me in at .049".Quench is a little loose but will be fine with aluminum heads.700 horse should be easy...probably on pump gas.When you get it running,look at total ignition timing.It should work the best at 28,29 degrees.Guys like to think more is better but not with your setup,from my experience anyway.Too bad you didn't get the B's.Would have worked as is with that cam.
I am going to be running a coil-near-plug system that allows me to map an advance curve. So with what you noted, I assume I should start with a straight line advance with max advance of 28-29 degrees. Any guesstimate on what RPM to be all in at? Should stall around 3500 and shift at 62-6400 rpm.Quench is a little loose but will be fine with aluminum heads.700 horse should be easy...probably on pump gas.When you get it running,look at total ignition timing.It should work the best at 28,29 degrees.Guys like to think more is better but not with your setup,from my experience anyway.Too bad you didn't get the B's.Would have worked as is with that cam.
Thanks again. The map is an advantage to me as I can back down the power anywhere in the curve depending on traction issues, launch, etc. Gonna be fun dialing this thing in.Those PAC springs are basically the same as the B heads,probably THE same spring.The Ford Racing B head,roller cam setup lift was 650-650 and they list the PACs at 650 max.Definitely plenty of spring for your cam but make sure to check for possible coil bind just to be sure.On the timing deal,the guys on the dyno set the total at 31 to start, made a pull,advanced a couple degrees,hp went down,kept losing power as they advanced.Started back down and ended up at the 28,29 figure,all in at 2800.We never messed with the curve much after that.The motor had same compression,b heads,slightly less cam then yours,Victor,Dommy 1100,521 ci,made 690 hp.We decided the carb was a little too small and would have gone over 700 easy if bigger.I was out of the picture after that and never really got it sorted out.
