1 - 20 of 23 Posts
Can you guys post pictures of how you mounted your alternators and the pulleys you used off of your balancers.. Thanks
fearlane send me a pm with your phone in it or jump on the teck chat tonight and i will explain it...i am a borderline old fart and have pic posting deficiency syndrome....bobn
Thanks.
I have a electric water pump, and i don't have a pulley yet for my Innovations West Dampner.. The brackets i have for my alternator are off of the 69 Lincoln, and won't work with the electric water pump.. Basically i want to find a pulley for the Innovations Dampner that is as small as possible.. what is out there? Thanks
Now that is just too cool! How did ya make it, Greg? Beat on it with a hammer or was welding involved?
It is folded in 3mm steel plate , then the top gusset is welded in and linished off smooth.. Machined the spacers to the block .Works well , all one piece makes it nice and solid .
I did another and had it chromed came up pretty nice . The bottom pulley is a clevo one machined back and water pump uses an aussie 6 cylinder one bolts right on.
Discussion Starter #14
Thanks everyone..
I ordered a crank pulley from CVF Racing... I ordered the 2v one and will machine off the 2v.. i only need one, but the single is to far from the balancer. Maybe i will keep the second for a Evac pump?? I will fab from there.. Thanks for your help guys!! Richard
what water pump or water pump pulley are you useing? with myset up i have a fan shroud and the summit 3300 cfm fan for a fox body mustang. i have very little room between teh fan blades and my water pump bolts. i am afraid it may touch at some point . so i am looking for a water pump or a single or doul groove water pump pully to give myself a little more room. right now i have the 3 gorrve water pump pulley.. any advice?
1 - 20 of 23 Posts
