Hello
I have a problem with motor mounts.I tried to mount my engine with new Pioneer motor mounts. After I swiched back original mounts, the engine went smoothly to it's place with no problems. Only problem is original ones are broken.
Original type is two part motor mount. I can unbolt the "rubber part" from the part what bolts to engine block. New ones also would mount engine too low and oil pan wouldn't fit where it should. They seem to have wrong dimensions. They look like quite similar but are one part type and have some differences if I inspect them carefully. One big difference is that old motor mounts have even surface where it bolts to the block. New mounts have one bolt hole and it's surroundings higher than the other surface.
I haven't even succeeded finding any photos from the internet of the old type motor mounts I have. My car is built september 1971. Rockauto sells same motor mounts for lincoln mk3 and 4 so I don't know if that makes any difference when my car is built.
Where I could find original types motormounts or is there something I don't understand with the new types motormounts?
Thanks in advance for responses.
