1 - 12 of 12 Posts
i have read using the eddlebrock PROFORMER PROFORM PACKAGE, ALUM HEADS INTAKE CAM IS WHAT COMES WITH THE KIT. I READ THE 69-71 HAS 10.5 COMP. THIS WILL BE GOING INTO A 75 LINCOLN CONNIE AND I AM SEEKING AROUND 400 HP I READ THE 69-71 STOCK WAS 3885 SO THIS SHOLD BE EASY ENUFF RIGHT? MY QUETION IS CAN I TAKE A NEWER ENGINE AND REBUILD TO THESE STATS?I WAS ALSO TOLD I COJLD FO TO 11 TO 1 IF I USE ALUMINUM HEADS AS THIS WILL NOT BE A DIALYT DRIVER RUNNING IT ON 93 OCT IS NOT A PROBLEM. ANY SUGESTIONS? I CAN PICK UP MID 70'S ENGINES AL DAY LONG IN MY AREA FOR AROUND 300 CAN I TAKE JUST THE BLOCK AND STATRT FROM THERE OR IS THE CRANK THE SAME? I DO KNOW I WANT FORGED PISTIONS AND IS IT WORTH IT TO GET A STEELE CRANK? I ALSO KNOW I CANNOT REALLY DO ANYRTHING TILL THE BLOCK IS BORED SO I KNOW WHAT TO ORDER. THIS IS MY FIRST BUILD SO SORRY IF I SOUND LIKE A DUMBASS BECASUE QUITE FRANKLY IU HAVE NO KNOWLEDGE OTHER THAN WHAT I HAVE PICKED UP OVERT THE YEARS. MY LINCON HAS 215 HP STOCK AND ITS JUST PLAIN GUTLESS I FIGURE DOUBLING IT WILL BE PLENTY. THAKNS FOR ANY HELP YOU CAN GIVE IN ADVANCE RESPECTFULYT YOURS....SAM FELTS MOORESVILLE NC
Welcome.
We just did a build for a 1973 Thunderbird which made 515 pound feet @ 3,300 rpm and 425 HP at 5000 rpm.
9.75 to 1 c/r. Performer intake. 750 holley. 219/227 voodoo cam. C9 heads with mild bowl work intake and a bit more on the exhaust.
Here is a link to the build and what was done. Perfect for a heavyweight car or truck. Copy it and your Lincoln will rock !!!
https://www.facebook.com/media/set/?set=a.563590983728292.1073741837.213179582102769&type=3
Same combo with an RPM intake will make 445 to 455 HP
:D
WHAT IF
I USE THE EBBLEBROCK RPM PACKAGE INTAKE CAM AND 75CC ALUMINHEADS ACRODING TO THE GUY I GOT THE SHORTBLOCK FROM IT WILL BE 10.5 TO ONE AS BEST AS I CAN FIGURE THIS WILL BE AROUND THE 505HP RANGE
You would be far better off if you listened to The Mad Porter and please quit using all CAPITOL letters when you type. Thank you and welcome aboard.
sorry guys
i am dyslexic proof reading is useless to me as i will alwys read the word intended and not the nor typed. i am 100% american 26th gen. family came here in 1740. looking to use the first one becaseu of the massive amount of tourque listed thats what i am really after. a guy in my town is sleling a stroker kit crank and rods that wold make same engine but be 545 with block only 30 over.
Welcome from Raleigh.
I just went thru the process of selecting parts to build a 460 stroker with not a lot of experience building performance engines. I think you're taking advice from too many people and that you'd do better to pick one 460 expert and follow his advice. There are several on here, just do some reading and pick one.
If you buy your parts from one of the 460 experts, you'll probably be able to get good answers to the dozen or so questions you'll have in the build process. That's how it worked for me. I bought the parts from Carl at carsbycarl.com and got his expert advice and answers that really helped me in the build. He'd not only give me the answers but was very helpful in explaining WHY certain parts were preferred before I laid out $1000s.
When you know what your objectives are, call an expert and see how the conversation goes. If you're not comfortable with your interactions with the expert, call another.
Good luck with your build.
Haaay vonfeltz68! I quoted this post because to me its a brilliant one. You simply and intelligently explained your spelling errors ,While I on the other hand usually use the more up-front and humorous approach of telling those who complain about my spelling or grammatical errors to simply F#@K OFF.
Needless to say, I'm no J. Christ with a torque wrench nor have I recently built a 460 based engine in which to propel a craft deep into outer space like others or anything like that. :eek: But I have d!c#ed around with a few BB Fords in my time.
Most important question I can think of here is ,What is your intended budget?
If you have recently hit the lottery or have a boat load of money to blow then definitely go titanium ,aluminum ,forged everything ,get everything new and the best and Have a competent builder to build your engine and you are good to go.
However if you are only looking for 400 or so HP and great tq, you wont need the alum heads, forged or titanium anything, and it shouldn't cost you a small fortune either. Sounds like a slightly warmed over and worked engine would make those numbers with no problem.
In closing, I'd say Good Luck with your build vonfeltz68, I wish you the best. However if it were me, I'D TURN THE CAPS BACK ON AND TELL EM if they have a problem with comprehending or communicating , SUCK IT! (That's why I have all the friends on here, ha-ha):D
I TYPE IN CAPS MOST ALL THE TIME TO,IT DOESNT BOTHER ME,MY FREINDS TELL ME I TALK LOUD,SO I GUESS I TYPE LOUD TOO,LOL
Rich, you're just a peach of a guy anyway lol.
Rob
thanks,it started about 5 years ago when the caploc key stayed in,lol
It has never bothered me when people type in caps,
IT'S WHAT'S IS TYPED THAT MATTER'S
1 - 12 of 12 Posts
