Status
Not open for further replies.
1 - 20 of 21 Posts
Do you need a stock short block or Race?
460
I have a fresh 30 over block ,used 30 over trw dish pistons on dooe rods with good bolts ,Pi heads ,victor intake ,new dizzy dist,,factory head bolts ,new sfi approved balancer zero balanced ,crank core ,asking $1800 will take an offer ,Pi heads have big valves ,good keepers and retainers ,springs good to 550 lift ,Thanks Nick D .Im in south carolina near charlotte n.c.,also have 1.7 roller rockers and a used set of comp solid roller lifters will throw in at that price .
C'mon fellas i know some of you have a stock to mildy modified 429 / 460 yall are wanting to get rid of for cheap let me know wat ya got
motor
Have a 460 with new stock pistons , mich 77 rod,main and cam bearings. Fel-pro gaskets--hasting rings--heads complete value job--for 750.00 plus ship-oh painted RED--thanks Fastfrog--803-528-8633--South Carolina
466
Where are you located? I have a 460 30 over kb pistons flate tops 190000 psi rod bolts arp studs oil mods comp cam, your choice one is 556 lift5 and the other is around a 505 lift double roller comp timing chain arp studs,high volume oil pump, d2ve heads ported intake and exhaust,comp valve springs, comp hyd lifters, stealth intake minus dist and dampner this is a running engine with approx 1000 miles. $1250 with intake $1050 with out I also have stock oil pan front sump and stock valve covers to go with engine Joe. Let me know if this sounds like what you wan't?
Short block .030 over , srp rods, weisco dome pistons,lunati solid roller cam double pinned frpp double roller chain, 272 280 .700 , comp roller lifters, canton box oil pan , Kaase oil pump , svo balancer. Has about 100 passes on a freshen up .$2500
429
I'm looking for a 460 to rebuild and stuff into my '66 fairlane racecar if you have a short block/long block let me know
I have a 429 that run pretty good.It is in my 68 f-100 that i am going to sell.The bad news i am in VA. I run the truck on the drag strip a 1/8 of a mile at a time.:eek:
wat did the car run alky or gas?
I ran it on alky. It ran a best et of 5.51 @ 124 mph 1/8 mile with tfs street heads ported by Charlie Evans. This was in a 2350 lb car. I actually bought the short block from Charlie 2 years ago. Several on the forum have seen it run and can vouch for it .
1 - 20 of 21 Posts
Status
