1 - 12 of 12 Posts
· Registered
Fords. We are located in the WV area and the only thing these shops know are SBC. and stock motors. Any recommendations for a good Ford Shop?
Has anyone ever done business with East Side Machine, Bill Mathias out of Waynesburg, Virginia? Was in his shop several years ago and he had several big inch motors for truck pulling and dragging. Seemed to know his stuff, but we also noticed several oil pans with major holes and broken rods and pistons nearby. Maybe just coincidence but I don't want my hard earned cash in the same dumpster.
Any help would be appreciated.
· Registered
I cant help.....
but it is good to see more mud racer's on here. Some one will chime in and help ya. I think Jason Massie is from WV. He raced in class 3 in the NMRO. He might be able to help ya.
· Registered
Eastside machine
They built one motor for me years ago.... Not enough clearance between the pistons and the heads. Bent every rod in the motor. They assembled the motor, all i did was put it in. They would not fix the problem and I ate it. Another friend of mine had them do a motor. It was a 600" with a new A460 block. The block was decked wrong and he ended up running two different thickness copper head gaskets to make the heads fit...Hope this is enough... :shock:
· Registered
Give Roger Decker a call. (330) 453-8383
Canton Automotive Machine Service located 2-1/2 hours north of you. in Canton Ohio. Tell him Coop sent you his way
You can't go wrong....
1 - 12 of 12 Posts
