1 - 7 of 7 Posts
I am looking for a solid roller cam similar to the Comp Cams XM288H
Adv. 288 304 @ .050 244 254 .580 .585
With all my input into Cam Quest it is the #1 choice so I would like to try one and see if it gets me where I need to be.
Here is what I got;
BBF 429
.030 (4.390), 3.59 crank, TRW 2366 Flat Tops, Mildly ported ex and cj entry C9 heads with 2.25 in, 1.75ex, the pistons are .007 in the hole and .038 head gaskets. I have a Victor 460 ported to cj specs and it is a Dom flang with a 2" 4150 adapter, with a 850dp sittin on top.
I need this engine to spin a MPD Heritage A impeller to a min of 5600rpms.
I have run the Comp XM 298, it was OK but not enough RPM. I installed the Comp 292H and it was better but not enough rpm eather. I barrowed a XR274R-10 and the mid range pull was real nice but it is not the ticked eather. So I want to try something else. I know this engine will turn the rpm desired. I want to stay with a solid roller.
Jim
I am looking for a good used one, I wish I had the funds to get a new custom ground bump stick.
zephyrracer said:
A little larger but I have a comp cam 319cr-10 if your interested.
Take Care Gregg 8) 8)
Thanks, but that is a bit toooooooooo big for my lil engine.
Anyone have a used shaft that is in good shape close to
244 [email protected] & .580 .585 ?
bruno said:
give Mr. Lem Evans a call he can definetly help you out with such a stick
bfevansraceparts.com
1-877-611-2613
So I called Comp and asked if they could cut this cam for me, I get a real good price with them, they said they don't have a lobe for it.
I will be calling Lem Monday !
1 - 7 of 7 Posts
