1 - 12 of 12 Posts
I have a 92 f350 I'm building into a open stock pulling truck I have dove heads on the motor not efi. I'm looking for fenderwell headers the class I'm building the truck for limits you to 1-7/8" primary I've checked in maddog but they only offer a 2" primary for the 90's ford frames I've found others but are only for the 70's frames any help finding a header that would work would be greatly appreciated thanks for taking the time to read.
Discussion Starter · #3 ·
I don't believe we are allowed to run up right headers but appreciate the idea. I'm afraid your right about having to build my own really trying to avoid that. I do have a buddy with a pipe bender but was hoping to find something before I have him tackle it with his bender don't want it choked off at the bends from his bender.
What if you bought the 2” type , and then removed the first bend and flange and made up 1.875” bends and new flanges and made them a step header.
That way the primary is 1.875” diameter, and your secondary is 2”.
that’s one of those gray areas, with wording.
Discussion Starter · #11 ·
I'll have to look into that! was hoping someone on here had the same build I can't be one of the first ones to run into this problem might have to buy the mad dogs as a template and send them back? You would think it would be pretty simple to just build them with smaller pipe since there already making the 2" work. I never understood why ford stuff is always more expensive and harder to find than gm guess quality over quantity! Thanks for the idea!
1 - 12 of 12 Posts
