I have a 460 that I'm going to put in my 79 f150 2wd with a c6.Its out of a 75 t bird all stock. Blocks in good shape and measures good. So planning on using stock pistons. The truck will be used occasionally for towing but mostly for cruising. Looking for 375hp and 450-500ft tourque. If the stock intake will do the job ill us it, 750 carb, comp extreme cam 34-235 . I have a set of dove heads but need totally rebuilt. Would I be better off decking the block and heads to up the compression and use the d3s.? Or go with rebuilding the doves just thinking that ill have alot of $ tyed up in the heads by the time I'm done. Thx
