1 - 6 of 6 Posts
564" Short Block
A460 block fresh 4.650" bore main studs, roller cam bearings, and bushed lifters
NNEW Scat forged 4.150" w/ short snout
Used but reconditioned Oliver 6.800" rods
TotalSeal AP .043 top, Napier .043 second, 3mm oil ring
Two sets of pistons:
NEW Wiseco 33cc dish for SCJ/P51 .043/.043/3mm rings, gas ports, about 11:1 w/ 75cc chambers, will handle lots of nitrous
NEW Wiseco small dome (0cc) for SCJ/P51 .043/.043/3mm, gas ports, about 15:1 w/75cc chambers, N/A only
Currently balanced for the 33cc dished pistons, not assembled and rings are not yet file fit.
$3800 and I'll split shipping, I get really good deals on truck freight.
NEW set of K1 7.000" rods $500
NEW QuickFuel 4150 1050cfm Alcohol carb $650
NEW TrickFlow "Mafia" 429/460 intake $400
NEW T&D shaft rockers for A429/SCJ heads 1.8 ratio $1000
NEW Aeromotive mechanical hex drive pump $400
Hogans C460 tunnel ram manifold. Dual carb and billet single tops, Linkage and sheer plates included, Carbs not included.
Made 1250hp on a 632 with a small camshaft. $1600
VED tunnel ram for OEM port location heads. Dual carb top with sheer plates, fuel injection bungs with rails (rails are not
pictured, i have plugs available if you didn't want to use EFI). This manifold is not quite finished yet. The hard work
is done but the port openings have not been finished yet. $1400
Moroso short sheetmeal valve covers $250
All prices are plus shipping unless otherwise noted. Call anytime after 6pm EST or TEXT anytime!
Derik
616-421-5747
Interested in the K1 rods .. please provide the part # of the rods.
What rod bolts did they come with??
Paul
THANKS Derik
checks in the mail............ I sent it from my bank bill pay Probably wont see it till Friday
If you decide to split up the short block, I may be interested in the Oliver refurbs and the crank. Steve
1 - 6 of 6 Posts
