1 - 3 of 3 Posts
Need room in my garage sale:
Koni SP-1 drag shocks front and rear 67-70 Mustang/Cougar barely used 150.00 fits stock front and rear suspension.
Competition Engineering housing floaters with bottom plate for Ford shocks used 60.00 Fits up to 3” axle tubes and stock width Mustang leafs.
Chassis Engineering double adjustable ladder bars used 125.00
1969/70 Mustang bolt on/weld on subframe connectors. used 75.00
Rear leaf springs, 69-70 Mustang, 428 CJ spec springs, stock ride height. Barely used 100.00
1969 –70 Coupe fiberglass deck lid, pin on. Stock style, no duck tail, fits stock quarter extensions. new 150.00
1969 Mustang 428CJ front coils new w/one full coil removed. 40.00
1969 Mustang 428CJ front coils used 40.00
9” third member used , 4.33 gears, 28 spline Detroit Locker, standard single rib case. 400.00
429/460 Edelbrock Victor with 4150, new in bag 250.00
Crane Mechanical Flat Tappet 289-302-351W used .525”I/.549”E 280/290 Adv. Duration 242/252 Duration @.050 108 Centerline. 60.00
Crower Mechanical Flat Tappet 289-302-351W used .622”I/.629”E 310/316 Adv. Duration 276/278 Duration @.050 108 Centerline. 60.00
Crane Hydraulic Flat Tappet HIT 292-2-NC 289-302-351W new .544”I/.546”E 292/302 Adv. Duration 110 Centerline. 100.00
Crane Mechanical Flat Tappet 429/460 used .583”I/.603”E 292/302 Adv. Duration 256/266 Duration @.050 108 Centerline. 125.00
Edelbrock 1725 new in box. 289-302-351w mechanical fuel pump. 70.00
Mallory 3755101 Unilite distributor used 289/302 150.00
2 sets Crites Gen 1 frame mounts and engine mounts for 67-70 Mustang/Cougar with 429/460. New set 100.00 Used set 75.00
Weld Drag Lights Front 15x3 1.375bs used 150.00/pr
Weld Drag Lights Rear 15x8 drilled for screws. 3.5bs used 225.00/pr
Moroso electric water pump drive motors, one new 55.00 w/new belt, one used 25.00
Electronics setup for bracket racing, used. MSD 6 #6400, MSD Softouch Rev Control #8738, MSD Two Step #8739, MSD RPM activated switch #8950, RPM module selector #8672, Autometer Pro Light #3240, Line Master single delay box. Set up to activate low rpm limiter when transbrake or line locks are activated, high side of two step for upper rpm limit, rpm activated switch utilizes the module selector to activate shift light/shift solenoid. Delay box holds transbrake or line locks for set delay time and holds low rpm limit of two step. Over 500.00 worth of electronics. 200.00
All prices DO NOT include shipping. I am in west central Florida 34602. email me at [email protected] for more info or pictures.
Thanks, Bill.
any pictures, not sure what they look like
1 - 3 of 3 Posts
