I picked up some ls1 heads for $75 and noticed the bolt pattern. Its pretty close,if you go from dead even in the middle only the outter edges barly dont want to fit.Other then alittle tooling around its actually a pretty easy conversion.I may step up to 1/2 bolts for this one. Most important is the pushrods,the spacing is dead even. :shock:
The coolent passeges are mostly is the same spots.Only the two top ones need to be filled in. Also the intake coolent doesnt feed into the heads. Which I think is good considering the freeze plug locations that it has,and simply custom intake.
Of course a custom cam is needed.But then agian any real build needs a cam.This was tried on a 302w.The build will be on a 393w stroker. The real reason is price/power. Its hard getting and used heads that can make serious power for less then 1k.That and ls1 heads on a ford is uncommen. Usually a ls1 with cam/intake/exhaust makes between 400-450rwhp on an auto trans. If you step up to an aggresive cam with a great port job,then the figures shift up alittle more.
