Anybody know if the mcleod street twin clutch would be a good investment or should I be looking at an even stronger clutch. Currently I have been running a ram 2800# PP with an 11" 6 puck metallic clutch. That has held to 600 rwtq but will slip into 4th gear with a 100 shot of nitrous. I have a big input toploader(1 3/8 - 10 spl.) and I noticed that summit has started carrying mcleod and they have a listing for a 12" street twin that is supposedly good to 1200 hp, but I know that hp ratings are funny :oops: You can make all the horsepower in the world, and still only have a couple hundred pounds of torque :?
Before I went dry sump, lowered the engine and changed to a smaller diameter 5 plate carbon fiber clutch I used the Street Twin and found it quite satisfactory. At that time the engine was smaller and making 800 HP. I would be inclined to give it a try, but you're just as well off asking the tech. guy at McLeod, especially if it is the same guy as it was 7-8 years ago. I always thought they were straight shooters - same goes for Tilton.
Like Fab Shop says - just talk to Red. Glad he is still there.
Clutches
I have wasted more money on clutches than any 3 fools should. It all stoped whem I bought a Mcleod soft lock sintered iron clutch. Our junk goes 8.60's at 152. Old car went 9 flat at 146{3000 lbs}. I have serviced my clutch once out of guilt. Call Red at Mcleod.
www.thefabshopheaders.com
any ideas on the billet steel, or the billet aluminum flywheel. I've been running an aluminum one and I figure that it will spin the tires even worse if I put in the steel one. I'm not sure?
