I have a stripped bolt to the mechanical pump. I guess the PO was hamfisted or whatever.
When I replaced the pump I wondered why it was jammed full of rtv, now I know.
My idea is just to get another bolt, little longer and attempt to nut it. Not a lot of space here though probably won't work. The back side has a little space but I'm not sure there is enough for a nut there.
Does anyone know if that will work, or what was your method for fixing?
Helicoil does not look like an easy job at all, I think I'd rather block it off and go electric than attempt that job.
I'd rather just keep the mechanical but I know it bouncing off the block is not a good thing.
Just maybe someone here has dealt with this situation and could save some misery?
