Hi all, just made the change to run Methanol in my now Rons Flying Toilet Injected 552 ci Front Engine Dragster and I just want to check out if its ok to store Methanol in a standard Steel Jerry Can at the track, or do I need something else... Many Thanks
If the can is lined it should not be a problem, dont let the drum sit directly on the ground, put some blocks under it so air can circulate underneath. Make sure its sealed tight.
