'73 block decked 10.300,.030 speed pro flat tops-plasma moly rings,10.1 comp, new cj rods, d3ve heads 2.19int 1.71exh, ported and milled to 91cc,comp magnum roller rockers, comp 270 magnum hyd flat tappet-224 @.050 519 lift on a 110lc, performer rpm intake,milodon 6qt front sump pan, motor was torque plate honed and balanced, have all receipts, maybe 600 easy miles, to make a long story short, i changed cams and had p/v clearance problems, motor runs great but valves are noisy, probably has a couple bent valves, warmed up 35 psi at idle and 60 psi at cruise will sell as a longblock or shortblock $1500 for the longblock or $1000 shortblock-i have over $3500 invested, must be picked up in cincinnati,ohio 513-479-3150 thanks marty
