1 - 20 of 27 Posts
new march press fit serpentine pulley 4 saginaw power steering 75.00
used front sump oil pan 25.00
used front timing cover has dip stick tube but with a plug on it also the seal can be changed from the front 45.00
aftermarket steel alternator bracket, power steering bracket with sag pump and ac bracket with a painted but never ran compressor, the ac bracket mounts on top of the power steering pump, not a fancy march set up but very clean compared to factory set up 400.00 for everything
used griffin aluminum radiator 22x19 believe part number is 26182 has some bent fins on it where the electric fan was mounted but it dose not leak 50.00 sold
used 18'' flew fan with spacer 15.00
i tried to describe everything the best i could if you have any ?'s pm, email or call 321-243-4456 mike be patient with me with my responses i have a 4 day old baby at home thanks all prices are obo plus shipping :cool:
mach alt brckt and 1 wire amp alt
new in box march alt bracket pn 30200 90.00
used rear sump frp fox body swap oil pan with pick up 75.00
almost new summit gm style 1 wire 100amp polished altrenator pn 61667AP 80.00 was only used for a short time then i switch to a serpentine set up
used stock 3 groove crank pulley 20.00
used stock 2 groove water pump pulley 15.00
how much for both? and what method of payment?
aftermarket steel alternator bracket, power steering bracket with sag pump and ac bracket with a painted but never ran compressor, the ac bracket mounts on top of the power steering pump, not a fancy march set up but very clean compared to factory set up 400.00 for everything"​
What sort of AC compressor is it? And do you have some pictures? My email is [email protected]
Thanks!
Ron
Thanks!
Ron
ron, ill send u picks as soon as possible!
Thanks!
Ron
Ron, pics are sent let me know thanks mike
1 - 20 of 27 Posts
