Status
Not open for further replies.
1 - 14 of 14 Posts
Comp. roller lifters, used #836-16 $185.00, Comp. pushrods 3/8" (1) pc. x .080 wall, (8)9.75, (8)9.35 used $45.00, Intake gaskets, new .060 thk. $16.00, .125 thk. $18.00, Comp. dual roller springs, #991 (used for mock up only) $75.00, (2) sets of K-Motion dual roller springs #K-1000H, used 260#@1.950, 820# open, $50.00 ea. set, Titanium retainers for K-Motion springs, used, $75.00 , CSR billet water crossover #904DRPKIT (complete w/ plate and s/s bolts) used, $75.00, MSD crank trigger distributor, #8569 W/ MSD wires, used $175.00, (2) Moroso throttle return springs for Holley 4500 carbs, used $16.00 ea.,(16) Jomar stud girdle nuts #1413 (7/16" 2.2 long x550/570 base) used $40.00, Crane rocker arm adjusting nuts. 16 pcs. new, $16.00, CSR flex plate,(168 tooth) used, $110.00. Other stuff (2) new stock oil pumps M84, $20.00 ea.(1) complete set of main caps w/bolts for SVO A-460 block, used $100.00 SHIPPING IS EXTRA, Thanks Joe SR. 707-864-0332
Banned
Comp. pushrods (1) pc. x .080 wall, (8)9.75, (8)9.35 used $45.00,
(2) sets of K-Motion dual roller springs #k-1000H, used 260#@1.950, 820# open, $50.00 ea. set,
ATI super dampner, steel hub, alum. shell, Glidden register for dry sump, (this unit is basically a small block unit and requires a spacer even when used on short snout) used, $185.00,
Moroso crank trigger assembly, #60000, (this unit is a small blk. Chev. and fits the register on the ATI dampner) used $70.00,
Danny Bee belt drive assembly, used $450.00,
SHIPPING IS EXTRA,
Joe maybe this will help easier to read
Randy
Joe, I left you a message on your phone. Please call me or respond to my PM. Intersted in the Danny Bee and ATI dampner, maybe the crank trigger.
Thank you,
Travis
301-478-3097 EST evenings after 4 pm
301-707-3462 EST Daytime 7 -5pm
Couger1969
Thanks for the help. Being a computor idiot, I will try to learn how to post in the fashion you displayed. Joe Sr.
Thank you,
Travis
Travis, I will contact you in the morning. Thankyou Joe Sr.
Danny Bee Drive
WHAT SHAPE IS YOUR BELT DRIVE IN
HOW MUCH SHIPPED TO ME
ZIP 6 04
The belt drive is used. It is the original cast unit. I recieved it with other items and never used it. It is in good shape,except at the cam access cover. Someone tried to drill out one of the small bolts, and really missed. But it is certainly fixable and useable. It comes with all parts including a good belt. Thanks Joe Sr.
Joe, just double checking, the intake gaskets are for the TFS A heads as well, if so I will take them both, also interested in the msd dizzy, does it have a gear on it at the moment, has the shaft been drilled for a gear change yet, may be interested in the crank trigger if its still available, have to see if it will fit my fluidamp balancer
Steve
Steve
The gaskets are for A460 heads. The distributor has a bronze gear, and has never been re-drilled. As of now the crank trigger is still available, but like yourself, someone is double checking their dampner. Thanks Joe Sr.
Discussion Starter #13
Steve
Steve, Did you receive my PM ? Joe Sr.
1 - 14 of 14 Posts
Status
