Moroso drag fronts 760 -15 No rot or cracks too tall for my car bought from a site member last spring $150
HOLLEY 250GPH electric fuel pump - never had fuel in it - $225
460 + 30 trw pistons and rings L2443f 30 used in good shape $200
Crane Titanium retainers new in the package part # 99663-16 - $100
2 powerglide converters -turbo inputs 1- coan 6000 stall behind 850 hp sbf $350
2-TCI 6500 stall behind 514 ford $350
750 vac sec holley with dual feed line $125
Air shifter 3 speed reverse pattern Precision Performance products with floor mt and netural switch 4.5 ft front exit cable no control box shifter only- New - $325
302 roller timming chain set New Summit racing # sum-g6620 $30
460 roller cams
Comp Cams 34-746-9 I .796 lift 285 @ .50 E .726 lift 288 @.50 New $250
Ultradyne ff 312-324 12r 738 lift I & E 282 I 292 E @ .50 -Used double pinned $200
All plus the ride. If you need pic send me a pm with your email.
Located in Kent Ohio
330 842 1886
C6 converter 10" 3200 stall behind 600hp big block $250
