6
Just thought I would throw it out there... I have some modular stuff I will not be using any time soon.
Cylinder heads... '96 Mark VIII heads with '96 Cobra camshafts (i still have the Mark cams as well if you want them, they have been milled .040 $300
timing cover with bolts $50
timing chain setup $75
Valve Covers with bolts (in primer) $100
Taylor spark plug wires $75
tensioner $10
bracket (not sure exactly what is is for, bigger aluminum one that holds one of the coil packs) $25
coolant crossover pipe and thermostat housing deal $25
power steering reservoir $10
engine wiring harness $100
