1 - 13 of 13 Posts
Moser 3.250 case, Moser 35 spline spool, Mark Williams billet aluminum pinion support, Mark Williams billet 1350 series yoke, Richmond Pro gears 5.43 ratio --------- $900 Nice center section with about 55 passes on it. 15 on the gears.
Travis Rice
Cumberland, MD 21502
Thanks Chris
555 notch / Not really wanting to part it out yet. see where this goes first. If you can find someone wanting the spool and gears then maybe.
61 Galaxie / It is the small pinion.
ONEBAD555NOTCH said:
it was $ 900 now its $900 firm
555NOTCH - It was $950 / Notice the edit above. I typed this message after realizing that an edited message would not come back to the top. Next time I will check with you before posting here .
Gearhead , I have someone interested in just the gears @ $175 . We will see where this goes but you can have the rest for the balance of $725 .
here is the new cost on this stuff:
M/E Case 3.250 - $335
Moser 35 spline spool - $190
Mark Williams Pinion support - $254
Mark Williams Billet 1350 yoke- $210
Bearing kit - $100
RCI carrying case - $35
Total - $1124
1 - 13 of 13 Posts
