BBF 555ci [/b]
- IDT Premier block
-Bryant light weight billet crank
-GRP 2000 pro series aluminum rods
-King main and rod bearings
-Ross digitize pistons and CNC domes
-Moroso custom aluminum oil pan
-Trickflow A-460 heads with custom titanium valves,alloy seats,psi valve springs,mainly titanium retainers,hardened locks
-Trickflow A-460 4500 intake
- Jesel custom rocker arms
- Jesel front drive kit with distributer
- roller cam bearings
- Comp cams custom grind solid roller cam-shaft
- Isky BBF .904 roller lifters
- Total seal custom piston rings
- BHJ lifter bore bushing's
- ATI balancer
- Danny bee thrust plate with double torrington bearing's
- Mainly 7/16 push rods
- 4 stage moroso dry sump system
- Moroso dry sump tank
- Moroso 4 vane vacume pump
- Meziere BBF water pump
- MSD flying magnet crank trigger
- BES sheet metal valve covers
- Dale cubic CFM 4500 carb with cnc spacer
This brand new setup only has 35 passes and just won the candian nationals runs consistantly 8.20's has been 8.22 @169.87 mph has been 174.66 mph on a 29.5 tire @3270 pounds.
also will sell converter with motor
-8'' Neil chance all aluminum billet converter bolt together with 3 billet stators.
serious inquires only email me at
[email protected]
