Hello, I have a few questions for you all.
I have a 429 I’m going to put into a Fairmont. I am running front and mid plates. So here is a little background info.
First of all, I put the car on jackstands and set the rear end to the correct ride height. I then adjusted the pinion angle. After that I placed the engine and trans into the engine compartment and put it basically where I wanted it (actually where it fit the best). Note: I am running a factory K-member with no spacers. I used a laser pointer to point the trans right at the pinion.
Here are my questions:
1 Since a 9inch rear end has an offset pinion is it correct to “aim” the transmission output shaft at it? By doing that my engine is not centered in the engine compartment but angled ever so slightly.
2) Should the engine be level, or is it OK to have it sticking in the front a little bit (angled up)? I don’t think I can level the engine with the stock K-member and the shape of the trans tunnel. I already modified the trans tunnel a bit, but I would need to really modify it a lot more to be able to raise the trans up to lever the engine out. And if I did that the trans output shaft would no longer be pointed directly at the pinion.
So that’s basically what I’m up against. This is the first time I’ve ever done this, so I’m happy to hear any suggestions. I would prefer to use the stock K-member without spacers if possible. Nothing has been welded in place so any of this can change. I am running a supercharger that is going to be sticking through the hood, so hood clearance isn’t an issue, but I don’t want the engine to be noticeably offset or not centered.
Thanks.
Wes
Thanks.
Wes
