I'm planning on putting a big block in my '87 Mustang hatch and I'm trying to decide on motor plates or motor mounts. Eventually I'm planning on going a bit more extreme and I'm wondering if I should just put motor plates in now or just use motor mounts. How hard is it to install plates? Does anyone make solid motor mounts for this swap? Thanks, Brandon
You only need to use ONE motor plate at the front of the engine and the regular trans mount in the rear; in fact it is prefered to do this with a driven vehicle unless you have a chassis which doesn't flex at all.
You don't need the engine and transmission to become a stressed member of the chassis; tends to break things especially trans cases and bellhousings.
Motor plates.
If your going to go to the trouble of installing a front motor plate, it's a good idea to also install a mid plate between the motor & trans at the same time. Using both plates at the same time reduces the load on the front motor plate, and spreads that load over a much larger area.
An engine/trans combo mounted with plates, (either front plate only, or front & mid plates), should still use a flexible trans tail shaft mount, (rubber or urethane). This is because all chassis flex to some degree no matter how many bars you add, (from a FOX body with only a 6 point bar, to a full chassis 'moly door car, they all flex some), and the thin aluminum trans case doesn't need any twisting forces applied to the tail shaft, main case, or valve body. Along with the mounting plates, a set of travel limiters is a good idea.
If it's going to be a mostly street driven car, a good set of factory style rubber or urethane mounts might be a better idea than the plates.
DAVID.
