1 - 7 of 7 Posts
Lets make some deals... everything must sell
Motor-
466ci motor, 71' block, factory crank, scat H-beam rods ARP Bolts, Speed Pro forged DOME pistons, King Bearings rod and main, Block has ARP main studs, Milodon windage tray, svo pump and pickup, Moroso Fox swap sheetmetal pan, new moroso dip stick and drain plugs, Liberty chain set and gears, comp cams custom ground solid camshaft and lifters, 666 lift area i have the cam card, comp cams hardend push rods, Trick Flow Street heads ported, P.A.W roller rockers comp springs, tall aluminum valve covers with studs. Victor 460 4500 flanged intake ported, 1" Hvac spacer, 4500 dominator 1050 carb, Billet Distributor, SFI balancer, Scat sfi Flex plate, Ford Racing 460 spark plug wires, motor is 100% band new never fired, and complete from carb to pan minus water pump $5000 you pay shipping or pick it up price is frim.
Or willing to seperate short block - $3000 + shipping
Heads with rockers and valve covers $2500 - Shipped
Victor 460 intake 4500 flange 225 shipped (sell only after the heads or short block sell)
Tranny Built C6 Forward pattern, NO BRAKE, deep aluminum TCI pan, new locking dipstick, built to hold 950hp tranny was built by Turbo Mike Florin, in Rochester NY, 100% new never installed $900 + shipping or pick up
Car is 1989 mustang LX original v8 5speed car, converted to automatic, 12pt cage done by randy jewl of Procar. full length sub frame connectors, summit seat, msd 6 box and 3 stage retard, lakewood 90/10 struts up front with eibach drag springs, and 50/50 shocks out back, 4:10 gears, posi, Fire wall built in back hatch area, with 10 gallon fuel cell mounted(brand new) and battery relocation kit, car has painless roll bar mount switch box wired in, all of the power windows and locks work, as well as all the lights, car will come with motor plate to put 460 into, has front plate (used) and brand new mid plate still in package, weld wheels skinnys up front and 15x8 in the rear with new street tires on them, $2500 you pick it up.
I will update this ad as i remember stuff i left out,
Just rememberd car has lakewood upper and lower control arms on it. and comes with a brand new line lock not yet installed
just bought some rental property, and time to fixem up and get em rented, so the toys are going for now,
Motor-
Do you have any pics of the car? I have a driveline. Sounds interesting.
Or buy the whole set up motor tranny converter car and motor plates and headers to put into the car for 8K, for $8,300 it will come with complete fuel system brand new
motor pics added, one of the motor when i brought it home from the machine shop and one the way it sits now with valve covers, intake, spacer, carb, and timing cover, distributor installed
1 - 7 of 7 Posts
