HEY SCARF!.....
I had the car out to US 60 Dragway in Hardinsburg Ky over the weekend. I was there for the Ford Big Block Bash. I had to get in my test & tuning before the race so I could see what it would run in order to call my dial in number. I made 2 passes Friday night and then 1 pass Saturday morning. That is when my electric fans gave up on me so I was not able to participate in the race (that just pissed me off). Upon further diagnosis I found that I had a piece of the plastic nose support come loose and push back into the electric fan on the passenger side. This not only stopped the fan dead in it's tracks but it also blew the electric motors when it tried to pull more amps to keep the fans going. I have both a relay & a fuse controlling the current to the fans and neither one of them shut the power off to the fans before it blew the motors. I'm not sure why... Anyway more work to do now. I'd really like to get my fans behind the radiator and make them pullers again instead of pushers. They are designed to be pullers anyway.
As far as the runs themselves goes I didn't go any faster than I had before but the times were close and there was a reason (5.83, 5.87 & 5.85). I had power pulled out & a lower than stall speed rev limiter set via my Digital MSD box from the last time I was at the track. I forgot my laptop so I could not put it all back in while at the track ( I know... I'm a dumba**). Anyway with all of that being said I was really pleased with the way the car went down the track with the new struts up front & coil over shocks out back. It launched like a Cadillac that could hook and went straight as an arrow down the track all 3 times. No drama what so ever. It was much easier to drive than before. I used to have to chase it with the steering wheel a bit but not now. It just hooked and went straight. The initial hit on the line didn't seem as violent either. The car didn't jump around at all. It just took off and went straight.
I'll keep you guys posted on progress. I'll be out of town for a while so it will be a few weeks before I get back to the track.
Stay tuned....
Maybe the fuses in the fan circuit were too high?
Looking back at your build thread you have the trans cooler behind the radiator and the fans out front.
Might be a PIA, but it might work better the other way around..and maybe add a third pusher fan in front of the cooler....your trans will run cooler too because the cooler wont be getting cooked by the radiator.
I have my trans cooler in front of the 3 row summit aluminum radiator (with a small pusher fan in front of that), and two puller fans in back of the radiator with relays.
I drove 25 miles to the track on a 90 degree day, 65-70 mph @ 3000rpms, mostly highway road, and the temp never went over 175.
Of course, I hit the two puller fans at a couple of traffic lights, never touched the front fan, and had all fans off while cruising.
I have never seen the temp climb above 175 with the fans running any cituation.
I have some Royal purple ice stuff just in case, but never used it.
5.80's is cooking man...you seem to like the way the car handled with the new shocks and the power turned down a bit...
...but maybe that's too boring :surprise:?
