MSD non programmable shift light part number 7552.
This compact Shift Light features a bright LED that will alert you to SHIFT! Fits neatly to your steering column or on top of the dash and illuminates bright enough to see easily in the daylight. This light plugs directly into MSD's line of programmable digital ignition controls. It can also be used with factory or other aftermarket ignition systems through an rpm activated switch. Brand new in the box, never been used. $50.00 shipped to the lower 48.
Autometer Pro Shift Light. Part number 5340. These independently-operating shift lights allow you to select the desired shift point by inserting a calibrated RPM chip directly into them. A yellow light turns on when the engine reaches the chosen RPM. 7000, 7200, 7400, 7600, and 7800 rpm chips included. Used but works great. $50.00 shipped to the lower 48 states.
