building mud truck
1975 cj5 fully boxed frame,dana 44 front,ford 9inch 4.10 gears in both.will be using 111 or higher race gas. havent purchased anything currently thinking 514 or higher stroker,block is D1VE factory bore,c8ve heads with 2.19 intake valves and 1.80 exhaust valves from ferrea, 1.7 roller rockers 3/8 pushrods and guide plates,will be running c6 and np205 t-case.will have around 5000 dollars to build heads have already been completed snd transmission is built just looking for engine build info.location is kc,mo
