1 - 6 of 6 Posts
Hi there. Those of you that have used this front clip conversion with the 460, what oil pan have you been using, that clears the front crossmember. I will be using front and mid plates with a glide. Any suggestions? Thanks in advance.......................Dale
Discussion Starter · #3 ·
I guess that info would have helped. Duh!! The car is a 65 Mustang with the Mustang 11 front suspension. I have not had the engine into this thing yet, as I bought it as a roller. Has anyone had any experiance with this combo? Going by the measuring tape, it will be damn close fitting all in behind the crossmember, but I think that is wishfull thinking. Really want to keep the engine down as far as possible, so maybe an external oil pump, and a custom oil pan are in order. Any thoughts?????????? Thanks again............Dale
Fox BBswap rear sump (actually called dual sump) pan. Available as stock type from Ford Racing (originally a 4WD truck part) or if you need more than stock capacity from most aftermarket race-pan builders (Canton, Milodon etc)
1 - 6 of 6 Posts
