Motor data.....
Dive block with Bluethunder 4-bolt caps on 2,3,and 4.
Eagle 4.14 crank
Eagle 6.8 rods
Manton 3/8 push rods
Comp SS Rockers
Jomar stud girdle
Old TFS intake
Arias Pistons They that are a shelf piston with the Dual Intake Valve reliefs cut. 7cc dome
The heads were done by Ford Performance Soulutions. Long story but do not have them do your heads!!!!
I flat milled the heads .100 only to get the chamber down to 80cc's.(Dissapointed) FPS ran a cnc program on part of the chamber and really opened them up to much.
compression ended up at 13.5-13.8 to 1.
Yes it is the 5106 Lunati cam that is in it now.
My new cam is 284 304 @.050 .830ish with 113 lobe sep. I have not installed it yet thou. I want to switch cams and re dyno and see what happens. The new cam should defenitly move the peak HP up. I think with this new cam it should peak around 7500 rpm and make 850 HP at least...I HOPE!!!! One thing I think is interesting is I think it would make a great street terror engine, if you could afford fuel. It really doesn't sound that radical,Sounds very healthy but not radical.
