1 - 6 of 6 Posts
have a 1987 pre-efi ford f350 with a 460 and a 4 speed. awesome truck but wont run. have gotten it to start and run a few seconds by putting some gas into the carb. put 5 gallons in the tank but we cant get it run:surprise:. hoping we can get some advise on how to go about this:grin:
Sounds like a fuel pump issue. Low pressure in tank pump failure.
You might also have a mechanical.
https://www.rockauto.com/en/catalog/ford,1987,f-350,7.5l+460cid+v8,1126392,fuel+&+air,fuel+pump,6256
SJ
HI, start by, pull fuel line off at the carb. put end in a bottle and turn the motor over (remove coil wire so it don't try to start). you should be a good squart of fuel into the bottle if not pump is bad or fuel filter or line is plugged.
good luck
tim
I'll have to agree; a truck that won't run will leave most people in awe. I'll also agree with everyone that it's a lack of fuel problem. Just check everything in the fuel supply and you will find the problem.
1 - 6 of 6 Posts
