My 94 Mustang:
460 .030 over
Stock crank
Scat h-beam rods
Probe flat-tops
C.R. is about 11.86
Dove-c heads 2.19 intake 1.76 exh. Ported, but no flow numbers
Comp solid flat .633/.633 and 262/272 duration at .050”
Victor intake 4150
BG 850 Demon (will be calling pro-systems eventually)
Electric water pump
Hooker SuperComp 2" headers
PA SuperComp C4 With trans brake
Art Carr 3500 stall 10” converter
28” X 10.5” Slicks
Factory k member, good springs, struts, and adjustable rear end.
I have 3.55 and 4.10 gears. Which should I use? I run mostly 1/4 mile but some events are 1/8 mile. Will the 4.10 work? How many RPM’s do you think I can get out of it? I would like to break into the 10’s. The car is completely gutted with a 10 pt. cage. It should be close to 3000 lbs.
Please feel free to comment, and let me know what you think it might run.
Looks kinda familiar... :lol: :lol: :lol:
I think you'll be happy...
Doug... 8)
Not sure whats all done to your heads etc, but its got to be in the 7000 rpm range.
Should be an easy 10 sec ride. I would run the 4.10 gears.
Good luck 8)
The heads were ported when the larger valves were put in. Not sure who did it nor do I have any flow numbers. Regardless they are temporary until I order a set of TFS Streets.
Thanks!
Good luck 8)
x2 Rick
