1 - 6 of 6 Posts
never used model # 13203 4 port regulator 4 6an outlets, 2 10an inlets
175.00 free shipp. lower48 states
Does the regulator have the fittings in it? Where are you located?
Banned
I would like to mention this is probably not 2 inlet ports one will be inlet and the other will be a return line outlet..... make sure you read the instructions... to which is which.....
Randy
hi guys, someone got a great deal on the 13203 regulator on e-bay, and randy, the two inlet ports i mentioned are inlet ports, this regulator has no return, you plug one inlet your not using.
thanks, richard
1 - 6 of 6 Posts
