Can someone recommend which flexible fuel line would stand up best to methanol? Do stainless AN fittings fair well? Thanks.
I run regular stainless braided rubber lines and an fittings and have for 3 years now.The key is to drain the alky on run some gasoline through them in the winter or let them set dry.I drain my alcohol and run a mixture of marvel mystery oil and gasoline threw the entire system before setting it up for winter.It will dry the o-rings out of the fittings and they may leak a little when you first run alcohol threw them but they will swell and seal shortly.
