puttin a new cam in my 545 and with the retainer for the cam in place no lifters in place there is about a 1 inch of play is this right or do i have a problem first time i've done a cam need help
Banned
with the retainer plate and no gear your cam will slide back into the block check the play after you install the timing gear... just a note make sure it turns real easy by hand so there are no tight spots...
Randy
