What I have so far.
-Box stock FMS Aluminum SCJ heads
-Core d9 block, crank and Double dot rods out of 94' F-250
-.030 over h418cp pistons 22cc dish
-Holley 3310 750 carb
The 460 will be for my 5000 lbs 1979 F-150 shot box 4x4. I do not tow, off road or race the truck, it's mainly used for hauling light loads, back up rig, and street cruiser. I intend to remove the 351m and t-18 I currently have (and hate) and replace them with the 460/ZF 5 speed combo.
At this point what would I need to round out my engine? I'm not dead set on the pistons I have, (most of this is just stuff that I've had from other projects, other than the heads) but would like to use my heads and core short block that I will have rebuilt and balanced. What would be a good choice in intake, cam, etc. Carb too Small? Strokers as of today are out of budget. Thanks for any advice. Goal 475-525hp?
Check out the horsepower sticky at the top of this section. Thats where I got this from. Welcome to the forum. Good luck!
475-500HP 460ci
Intake System:
750cfm Holley DP Carb professionally calibrated for your application
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
Roller rockers.
Short Block:
Comp Cam XE274H Hydraulic flat tappet cam or equivalent
(Specs:274/286 adv., 230/[email protected], .562/.565, 110 LSA)
Compression at 9.8:1
Stock crank
Eagle I-beam rods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91 octane. Keep redline to 6500 rpm.
I believe the heads you intend to use, requires a special piston. It will have a valve releaf in a different location.
^^ Yea, that I know, I'll need to check and fly cut or get the correct piston.
I have seen the HP builds, just throwing this out for my specific vehicle and application.
