I know this isn't in a mustang or related, but I'm having trouble starting a new 460 in my 71 ford truck. It is completely rebuilt from top to bottom. I went from points to duraspark when I rebuilt the motor. I also put in a 200 amp alt from a EFI 460 out of an abulance. I wired it up like I was wiring in a 130 amp alt. I also used the serpintene belt system out of that same EFI 460. So I finally have everything wired up and ready to go. I pull off a carb from a running parts car (74 Lincoln w/ 460). That 74 lincoln runs like a champ so I decided to use the lincoln carb to break in the motor, then I will swap to a holley 750. So I'm all ready to start the truck. I pulled the dizzy and used my air tools to spin the oil pump (CCW) for 3 minutes. Then I put the dizzy in and tried to crank it up. I got a couple of small pops out of the carb so I knew the timing was off. Sure enough I pull #1 plug and use a large wrachet to turn the motor over. I set the timing to 40 BTDC and start moving to 10 BTDC. I don't get any compression so I know I'm 180 out. I pull the dizzy, move the motor 180, set it to 40 BTDC and then move it to 10 BTDC. I gets lots of compression w/ my finger over the spark plug hole so now I know I'm on the compression stroke. Set the dizzy to 10 BTDC and all it set. I hit the key and it just turns over. I put a little gas down the carb and it still doesn't catch. I adjust the timing a little and it still doesn't catch. Adjust the timing again and still no catch. I know gas is getting to the carb. I know the carb runs great in the lincoln. I know I'm at least close on the timing.
What is the best way to check for spark w/ duraspark? Do you just put the plug to the block (wire still attached) and hit the key to check for spark. Thats how I used to do it w/ the points, but I'm now sure w/ the duraspark. Anything else I should check?
Can you check the timing w/ out the truck running, just by turning the motor over w/ the starter w/ the timing light hooked up?
Lots of things have gotten in my way over the last couple of years (yep, I've had a new motor in my truck for 2 years and I'm just now getting to try and start it), and now that I'm finally close I really want to get it done. I have about ten things I want to do once I get my truck running.
I'm going to check the firing order first thing when I get home tomorrow. Just to make sure I thinking the right way, the front two cylinders are #1 and #8 correct. #1 is on the passenger side and #8 is the front of the drivers side.
thanks
Austin
thanks
Austin
