1 - 12 of 12 Posts
Crites makes them but they fit like 💩!! The front two tubes on each side go in front of the control arm and wrap around underneath. I believe Maddog makes a two different styles, one like the Crites and a traditional style where all of the tubes go out the back. When I asked about the traditional style they couldn’t send me any info or photos🤷🏻‍♂️
Discussion Starter · #3 ·
Thanks for the info. Thinking im going have to wait till i pull the old engine out. Then I'll takes some measurements from it and a 69 mustang and do some comparisons.
FPA makes them for pretty much everything. Crites aren't bad but you do run into ground clearance issues depending on ride height/tire diameter. I've run them on my Mach 1 for years.
I used the Mad Dog multi-piece headers on a 62 Galaxie with a 460. They run around the front of the control arms as stated. Fit was good but they do hang pretty low. Big primaries and 3.5" collectors. I thought I had pictures on this computer but I guess I don't...
Stan Johnson at FPA has headers for this application in both std and CJ flange. They are a mid length style and will easily handle 600+ hp
FPA is a few miles away from my shops.
Tell him Scott with Parkland RHP sent you.
I've had his headers on my 1973 ltd for about 10 years now.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
Hey Scott
Have you ever inquired with Stan about building a set of his headers with bigger primaries and collectors? I’ve called and sent emails before but never received a response. I have the same vehicle application as the OP and don’t mind the mid length style but need a bigger tube to support more 🐎
I have. We've even discussed using my LTD as the prototype for full size.
What is comes down to is demand.
What specific application are you looking for?
The FPAs will hang with hooker super comps until about 630 hp and up to 700 the losses are 25 hp?
Custom ground cams
R-H-P.biz
(253)-988-6648
1964 Galaxie with a 547 that you provided the cam and pistons for. It made 717 and 695 through a 1 3/4 shorty bronco header and 850 carb on the dyno. I didnt have a bigger set of headers to try so there was no sense in throwing the dominator on.
1 - 12 of 12 Posts
