Hello Guys,I've changed my combo up and is wondering what HP #'s should I look for.
This was a 557 in a stock block w/A heads it made 930 hp @6400 and 813Tq @4800.With thosew numbers in mind I decided to switch everything out and into a A460 block.From there I decided to up the CI to 598.I bought a set of 4.600 diamond flat tops.My Compression ratio is gonna be 14.8 to 1.Heres yhe list
2 pro systems 1050 doms
trick-flow Holmes style intake
Motorsports a 460 heads [email protected]@800 exh.
cam is [email protected]
865-830 on 114 installed 112
4.600 diamond pistons gas ported w/ pin Upgrade
6.800 Oliver Max rods w/625 bolt upgrade
4.500 crower crank
1.75 Jessel rockers
Danny Bee Belt drive
A-460
Pro Shot Fogger set up for 250 shot.
Kasse oil pump
What type of Hp should I be looking for out of this combo?
It's going in a 2650lb MustangII Glide,456 gears,15x15x33MT's Hoping to have a little fun
hey 514 we have the same build! but I have the tfs new single plane intake with a 1250 dommy! same pistons and heads. should be able to get about 960-1000hp! my intake is plumb for a fogger by steve Johnson. hoping for the sametype of #'s
4.500 crower crank
1.75 Jessel rockers
A-460
Kasse oil pump
If you want to see an increase in power, won't you need a cam with an extra 10 degrees duration or so to feed the extra 42 cubic inches? And maybe an extra degree or so of lsa. Or do you want the power to come in at a lower RPM? Maybe the nitrous negates this need. I'm not a pro, so I'm just asking. Seem like asking one of the professionals on this site is in order. At any rate, it must be exciting to be making this step. Best to you and youir project.
Hey Pick514 how's it going??? we will have to start calling you Pick598, LOL!!! well I have a couple of friends that have a 598 and a 604 with A-heads and they both make over 1050HP :eek: :D so you should be in the neighborhood too!!! so good luck and keep us posted
Hey Mr.Bean its been a while.Yea you are right about Pick 598 I like it.I hope you're right about the Hp level.gnna hit with 300 shot.This is my last upgrade.I'm getting old and brittle have 2 be more careful.lol
